fiberglass and urethane repair
I have a few questions concerning the repair of a fiberglass hood and rear bumper cover. I have access to a plus hood with a few chips, one of which is down to the fabric, and a few small cracks--likey from regular use. Does anyone have a recommendation for a particular product to fix the chips? What about the cracks? Is there something needed to keep them from reappearing when it gets repainted?
Rear bumper cover- a good sized chip at the bottom of the bumper cover. It doesn't go all the way through. Is there a preferred product to repair this before painting?
rangerj
Brunswick, Ohio
Luigisho,
Find someone in your area that specializes in repairing fiberglass, or making fiberglass parts.
The bumpers can actually be welded if they are torn. There is also a filler material made for them. Try WWW.eastwoodcompany.com. The sell a lot of restoration products for the pros, and shadetree mechanics. rangerj
ericglo
miami
Hi Luigisho,
I recently attended the NACE show in Orlando. I came acros a product called Plastex. It looks like a very good product for your bumper. I am testing it to see how good it is. From what I have seen so far, it looks like a winner.
As for the hood, I am not sure if this product will work or not work. It should, but don't quote me.
The price is only about $20. So you shouldn't be out much. Incidently, the test pieces as the show were very impressive, unbreakable and stuck to anything.
Sincerely,
Eric Green
iselltonsofthings
Western Pennsylvania
I do a good bit of fiberglass work myself because I'm really into performance jet skis. It never fails that I'll get a ding or chip in the fiberglass every now and then.
I have spoke with numerous body shops in my area over the years and everyone recommends "Lord Fusor" products. I used fiberglass resin & cloth and do it the old fashion way until I started using the "Fusor" products.
This stuff is the best, hands down. It is 100 times easier to work with than old fashion resin/cloth and is probably 100 times stronger too. I've never had this stuff crack or chip.
Just attach a special mixing tip to the cartridge, use a standard caulking gun "you do have to buy a small $15 attachment but it is a one time purchase that should last forever", insert the cartridge into the attachment, and then the attachment into the caulking gun.
The "Fusor" products are roughly $12-$15 for a small tube, but it will do an amazing amount of area for that little tube. Plus, the first time that you see how easy it is to work with, you will never go back to the old way again!! It is well worth the money. This is truly, you get what you pay for situation.
Here is a picture of the Fusor "101EZ" compound that is special designed just for Fiberglass.
By the way, you can get this stuff at most all autobody paint suppliers. If you are having difficulty finding it, I'd be glad to get it for you. I'll do it strictly at cost. The store is only a block from my house. I'd be happy just to help ya out. If you need some, just PM me. Sincerely, Scott
