Failed emissions for the second time today...
Groo
Glenview, IL
While my results were a little better, I failed again today. Even though I replaced the plugs, wires, and O2 sensors.
Groo
Glenview, IL
The only test I failed was Hydrocarbons (unburned fuel). It was 1.40GPM, when it should be, at most, .80GPM, according to the EPA.
I passed Carbon Monoxide, with 9.0GPM.
My Carbon Dioxide results were 531.7GPM, which they don't pass or fail you on. And my Oxides of Nitrogen count was 6.20GPM, if any of that helps.
jbeano
Caledon, Ontario
Last week my 95 mtx failed miserably. The only thing it passed on was co. The HCs were 106 ppm and the NO was 2146 ppm. I replaced the wires, plugs, O2 sensors and the cats. The car passed upon retest but I still had HCs at 35 ppm. This concerned me as I didn't want to overheat the new cats with so much unburnt fuel. I then had the injectors and combustion chambers cleaned using a "motovac procedure". I returned to the testing shop and got an HC value of 2 ppm. Hopefully my experience can help you.
Chrisssssssss
vancouver, BC, canada
jbeano, where abouts in Canada are you located? I am in BC, Lower Mainland Vancouver Area.
Groo, Try the methyl hydrate trick. I think that this will help lean out the system. What I would do is with about a quarter tank of gas, put about 1 liter (quart) of Methyl hydrate in your gas tank, then run your engine for a good blast on the highway to get it up to operating temp, then go directly to the testing facility. Get tested. Pass test. Then fill up again to the top with the flavour of gas that you would normally use to dilute the methyl hydrate. You do not want to drive with great amounts of this stuff in your system foe a long time.
Good luck!
PROPHET
Well-Known Member
Tonytown, Texas.
If all else fails .Try water injection i have it on my 92 sho .Steam cleans motor while you drive,carbon cleans, keeps plugs and sensors clean,i run alcohol for more pep .the motor just loves it runs so smooth cant believe the difference .No exhaust smell at all just hot steam coming out. burn_out
Groo
Glenview, IL
Prophet...why are you still posting here?
I pulled the codes today. There was only one, 332, "EGR valve opening not detected".
<small>[ July 13, 2002, 02:43 AM: Message edited by: Groo ]</small>
