jtmartin8819
I've read on here a few different times about guys running stock cat back. Are you guys deleting the 3rd cat after the X pipe? And are you cutting out the X pipe as well?
I cWe don’t have a factory X pipe. Post downpipes it go’s to the third cat then out to resonator.
Are both sides merging in a spot then exiting, yes. Essentially an X pipe, no.If you cleared the catalyst material from the 3rd cat, wouldn't it essentially be an X pipe?
I like it...And this Ghost Cam....this is just a tune correct? Does it perform like an unleashed/LMS tune?I have removed my 3rd cat and stock resonator. I replaced it with a custom set up with a Magnaflow Resonator.
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-19
PPE Catted DP, into this set up, into stock mufflers. I have videos with the sound as well.
can it be added to an existing tune? Really like the soundA Ghost Cam is a tune. It messes with the valve timing at idle. It drives normal when you press the gas.
However, it can smell like raw fuel sometimes, and while idling in drive the car tends to surge. Really a gimmick, but cool still.
If your tuner does it. I know AJP and Ortiz do.can it be added to an existing tune? Really like the sound
