Exhaust
jtmartin8819
Indiana
I've read on here a few different times about guys running stock cat back. Are you guys deleting the 3rd cat after the X pipe? And are you cutting out the X pipe as well?
jtmartin8819
Indiana
A Ghost Cam is a tune. It messes with the valve timing at idle. It drives normal when you press the gas.
However, it can smell like raw fuel sometimes, and while idling in drive the car tends to surge. Really a gimmick, but cool still.
jtmartin8819
Indiana
can it be added to an existing tune? Really like the sound
yaycandy
Aerospace Engineer
Hanover, PA
Ghost cam never worked correctly with AJP, after a few ghost cam adjustments and idle rpm adjustments it started to get better but would only do it for 10 seconds or so. Sounds good, might feel better with better motor mounts also. With the idle pulse being forward to back because of the fwd layout, it feels weird. I only had the tune in the winter and havent reflashed it since it warmed up, maybe its better in warmer temps. Ive just been on the normal AJP tune
