exhaust removal from resonator back
medgraphsho
Bill T.
Bridgeport, CT
Im trying to get the exhaust off, basically both mufflers have already fallen off and I have the clamp removed from the resonator but it just wont budge??
92sho16
b00sted
Liverpool, NY
This is a stock exhaust? Well either way stock or aftermarket if the mufflers have fallen off, im guessing from rust, your never going to get it apart without cutting.
When the clamp gets tightened, it squeezes a little ring into the inner tube, so they are stuck together even w/o the clamp being there. You will need to cut the outer tube open (split it) with a Dremel or die grinder to get it to come off.
