exhaust questions
waffles
Minnesota
I'm a bit off a noob around cars but i'm learning. I was poking around the forums and I see alot of things refering to a "catback exhaust", does that just mean there is a cat on the exhaust? I see when you buy a muffler it says it's a catback, does that mean you can use it on a catless system? what are the advantages to a catless system? also what does a resonator do? Thank you :thankyou:
lowc
aka vapah lock
Quincy, massachusettes
all at catback system is the exhaust from behind the cats. all cars are supose to have cats on them, i run a catless system on my car and you actualy lose some low end power. as far as a resonator it helps to tone down or get rid of rasp in the exhaust
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Catbacks are from from behind the cats on back and includes the resonator and mufflers: Catback
The cats are on their own and contained in the y-pipe. The y-pipe is better for the top end but you loose the low end. You also get rasp. Cats keep the low end and the sound is more mellow: Y-Pipe
waffles
Minnesota
Thanks
