Exhaust leak at turbo ******
Shhoebow
Melbourne, Kentucky
Found an exhaust leak at my turbo ****** do to stripped exhaust stud. just wondering if anyone has had this issue. And if so how did you go about fixing it?
Found out my sho was starving for fuel at wot, so I got under it and found a leak on the passenger side turbo at the ****** there was suet on the boat and where the leak was.
Sent from a form of communication,at nearly the speed of light using the internet.
MCIntimidator
Florida
Anybody can feel free to correct me if I am wrong, but you may have to use a bolt extractor to get it out. Only if it is broken at the mating surface. I don't own a 4th gen but have delt with many stripped bolts in my 3rd gen. Lubricant is a must before you start wrenching on it. Extractors haven't failed yet with exception to a Honda. Hammered a 13mm socket down then over a stripped 14mm bolt head and got it. You may even be as lucky to get a good grip on the stud once you open the ******. Good luck with the stud.
