NJatx
you probably got a ATX pipe for your MTX. The flex pipe is needed because it is a front wheel drive car which means the engine flexes front to back instead of side to side. which you then need a pipe to flex.
NJatx said:you probably got a ATX pipe for your MTX. The flex pipe is needed because it is a front wheel drive car which means the engine flexes front to back instead of side to side. which you then need a pipe to flex.
