Exhaust Install
NJatx
Branchville NJ
you probably got a ATX pipe for your MTX. The flex pipe is needed because it is a front wheel drive car which means the engine flexes front to back instead of side to side. which you then need a pipe to flex.
SHOBlu
Habitual Offndr
New Sharon, Maine
He has an ATX car and recieved an MTX midpipe.
BTW Morpheus........You could always install really stiff motor mounts. Then you won't need the flex pipe.:nut:
If you do need a new flex pipe, contact Exhaust Direct Performance
They had a flex in stock for my ATX with the Dynomax cat back system. They customized it for me too, expanding the last half inch a quarter inch in order for it to fit over the dynomax midpipe instead of inside it. They are a top quality outfit! :thumb:
Also check with Summit and see if they will send you out a ATX midpipe. I think RockAuto sells them too. Good luck.
