error code help!!!!
mccrackalock
colorado
I have a 92 sho that is giving me problems. She will sputer and die out of the blue. I erased the memory then drove her until she acted up again. I then hooked the obd I tester to it and got three error codes. 211, 214, and 219 this was in the KOEO test. Can some one tell me what this means and where to start:)
sperold
Last to Know
Here are some code readouts:
211 - Profile Ignition Pickup (PIP) circuit failure.
214 - Cylinder Identification circuit failure.
219 - Spout signal defaulted to 10 deg. BTDC / Spout circuit open.
Your first code suggests crankshaft position sensor problems, either clean off the fuzz or replace, usually people replace them due to the work to get to them.
Your second code means your code reader can't tell how many cylinders your motor has. Do the test again as that is a new one.
Your third code states Your spout has been pulled. Look on your decal on top of your rad to locate the spout (usually right over your power steering pump at the cowl on the passenger side). The car will have poor performance with the spout removed. Search "pulling the spout" on this forum as TOSHO has a write up on the matter.
You will get help quicker if you post in the "Help and Maintenance" section rather than the "Performance Upgrades" section, but you will learn that over time.
You have ignition trouble codes. The places to look first are the DIS module and the PCM.
