erratic idle when slowing down(MTX)?
JaySHOguy
Bellingham,MA
Guys, I have a little, uh, problem with my '89 SHO.
Sometimes after coming down to a stop, the idle will bounce between 1,000 and 1,500 RPM's for 20-30 seconds, then even out and drop to about 900.
Any idea what could cause this? Throttle is not sticking, and car runs and drives fine otherwise(besides running pretty rich, but I am not concerned with that).
Thanks for the help. pizza
haydenm315
Reisterstown, MD.
I think the bouncing idle can be attributed to a rich running condition. Maybe the computer is making the car rev so it can burn the excess gas instead of stalling? You might as well clean the iac/iab valve. I've seen a number of people have fluctuating idle problems from a dirty one of those. Other than that... I don't know. Good luck with everything. Please let us know of your progress so others will be able to find it in a later search :)
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Try cleaning the MAF sensor? and the IAB? I would say that best guess - your IAB is bad. Just a guess, though, and cleaning the above 2 will most likely solve the problem.
Unless your oxygen sensors are not working your engine cannot run rich. Why do you think it is doing so?
The idle speed is governed by the air that is allowed to enter the intake through the idle air control valve. It could be that the feedback signal from the IAC valve is erroneous and confusing the EEC. This would be an electrical problem due to wear and age and would not be correctable by cleaning the air passage section of the IAC valve. You will need to replace the valve to correct this situation.
Another possibiilty is a vacuum leak, but this would also be apparent in other ways.
JaySHOguy
Bellingham,MA
Running rich: Belches out clouds of black smoke on hard runs(mixed with some blue oil smoke occassionally) and my muffler tips will be completely carboned up within 3 days of cleaning them. The exhaust also smells stronger than other older vehicles that I have owned.
No codes, so I am assuming the o2 sensors are working.
I cleaned the MAF and the entire intake(including any and all sensors on the intake) about 2 months ago.
I will live with this until it gets to a point that it affects the driveability of the car.
Up until 7,000 miles ago, I have NO idea of the history of the maintenance on this SHO.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Circled here:
This picture belongs to Panama Pat. I added the Circle. hail
<small>[ September 04, 2003, 06:25 PM: Message edited by: AutoSHO ]</small>
PROPHET
Well-Known Member
Tonytown, Texas.
Thanks alot Chris couldn't be any clearer. hail
<small>[ September 05, 2003, 03:06 AM: Message edited by: PROPHET ]</small>
PROPHET
Well-Known Member
Tonytown, Texas.
Is the IAC valve the same on all the gen ones and twos are they interchangeable between the ATX and MTX computers?i ask because i have an extra one with an intake just not sure from what year.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
PROPHET:
no, they are not all the same as the early gen 1's had 'cleanable' AIBs. But I beleive that they are all interchangeable.
FYI, I just replace the AIB in my brothers Exploader and beleive it or not, the AIB looked identical... even had the same plug eek! shrug
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
On second thought, I would check all your vacuum lines very closely. A small leak will only manifest itself under high vacuum, low flow conditions, basically, at idle. I would also check the fuel pressure if you have reason to believe its running rich.
munkee
Too busy...
Missoula, MT
It may not be the case with yours but the 91 I am driving right now is low on refrigerant and when I turn the defroster on, the cycling of the compressor will almost make the car stall(needs 60k) then rev to about 1500 at a stop sign.
