johndallara
Recently got a set of BBBs and replaced my stock upper intake w/the new one. Same throttle body, the DIS and other stuff was new from the rebuilt intake. Also replaced the plugs and wires w/ stock items while intake was off.
After replacing the intake, I couldn't get the engine to crank. Checked all the connectors, and hadn't grounded the intake properly. Re-tried, this time got 511 (ouch), 116 and 636 codes. Had a spare PCM, so I replaced it and this time got different codes: 11, then 663/611/6?, then 11 followed by 512. Also tried zero-ing out the computer by 30sec brake pedal w/ battery off, and the second set of codes persists.
Any ideas? Fuel pump is coming on, engine is turning over and engaging, is running roughly w/ backfiring through the TB and quitting when foot off the gas.
JD
JD
