thecrew2999
3.2 MTX SHO
ok now this question is different and no one say search it because im not even sure how to search it.
ok i got a 95 atx and i converted it to mtx and kept all the wiring and computer from the atx but just adapted it to mtx.
question is since im having problems with wiring and the computer acting weird im gonna try and make a different approach to fixing the problem.
i wanna take the mtx engine harness and use it to my atx harness that goes into the car.
i tried to hook up a 92 mtx wiring harness to the main harness and it didnt fit but i know the wiring and pretty much all year SHOs are different in some way.
now the wiring harness im talking about on the gen 2 is on the drivers side inner fender behind the the cruise control box on a 95 atx on the fender. i wanna use the atx body wiring harness and the dash harness and put what i believe would be a 95 mtx engine wiring harness and computer in the car.
would this work ? i know there might be a few issues to work out like the clutch interlock switch might be sorta a hassel to get figured out but im sure i can by pass it. any other issues i would need to over come?
i think this would be the best bet for a 3.2 atx to mtx swap since there would be no wire splicing like for the alt and the oil level sensor and the started depending what starter you use also.
if the harness plugs in im not sure if you would lose function to certain things like reverse lights or anything else.
if all else fails ill be looking for a pretty much perfect shape 3.2 wiring harness and a computer
any help would be great
