Engine Trouble
SHOman247
michigan
ok first of i'm a memeber of TCCa and am look to buy this 93 red sho...it has 250,000 miles and is the atx 3.2...anyhoo the owner says he's getting rid of it cheap because the oil pressure light comes and it starts to knock..any ideas on what it maybe?...rod bearings? I was just going to fix it up long enuff to find a replacement engine...anyone got one?..Me and a fellow tcca memeber and avid sho owner are going to go look at it sunday...any advice or suggestions are appresiated...thanks again
Greg
Mr Anonymous
Tire Wall
Almost definitely rod bearings, possibly a bad oil pump and ruined crank to boot. With those kind of miles and the condition of the motor, I wouldn't recommend paying more than about $500 for it.
SHOman247
michigan
what if it was only ran for a few minutes with the knocking and oil light...would it automatically ruin the crank? he was 1000 and it's worth it..car perfect other than the engine trouble...make my money back parting it out if i can't find a engine
stevetatro
Cincinnati, Ohio
There's no reason the crank would be ruined. It may even be safe to drive it home, if you put some heavy oil in it. I know a few people who've had to do this.
If the crank's okay, pop some new bearings in it and go!
Mr Anonymous
Tire Wall
stevetatro:
If the oil pump is bad or a rod bearing has spun, how is thicker oil going to fix that? shrug It's silly to risk further damage to an engine which is already exhibiting a serious problem, potentially taking a repairable problem and damaging it beyond repair.
Every minute that car is run with the oil light and rod knock damage is being done. Unless the seller is a blood relative, I wouldn't recommend trusting his word about how long the engine has been run with the oil light and rod knock.
The risk of major damage here is too high IMHO to justify spending $1000 on a car with 250K! If the car had less than 150K, I might consider it, but with that many miles you might fix the engine just to have the tranny crap out on you a week later. Until you actually open up the motor and inspect the key components, you can't know what the extent of the damage is, and should assume the worst. You might be looking at spending another $1000+ just to get the car in roadworthy condition. For $2000, you could find a much better SHO.
There are many other SHO's out there with fewer miles, good maintenance histories, and perfectly running engines. In fact there's a blue ATX in MI listed for sale here in the forum with 90K miles that you could probably buy for around what this car would cost including repairs, etc.: http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=7;t=000054;p=1
IIWM, I would steer clear of this car for anything more than $500. What you do is up to you, but I think your money could be better spent.
SHOman247
michigan
well going to go look at it witha friend...anyone know Tara? were going to look at it sunday...go over it witha fine tooth comb..i know it can get at least 2's in parting ti out if the engines toast...but have sho in waiting with less the 80 k it for 150 bucks...wrecked 91 sho..anyhoo thanks for the tips and keep em coming and i'll update ya on sunday when i see it....thanks
David Carpenter
