Engine surging and backfire after 60k
BenSwanson
Nashville, TN
To keep it short:
Finished 60k
Started fine, Test Drive, Oil Leak
Remounted back valve cover
Now Engine surges with a high pitch whine and backfires then dies
The only thing i did different was tie back the wires in the area of the CID, checked it out and everything was connected
No codes, ant ideas?
N3FOL
Pennsylvania
I second the idea...everytime the word backfire comes to mind I always think about spark plugs and wires. That brings back memory of my old garden tractor that backfired a lot before I replaced the spark plug and checked the gap. boink
shostang
Virginia
Also check to make sure you connected the ground wire on back of the engine and that all bolts are tight. I had the same problem after removing and replacing my intake manifold-turns out I had left two bolts loose holding the crossover tube to the lower intake. This caused the DIS module to lose it's ground.
SHOtimer
#2910
Santa Clarita, Ca
What do u mean wrong bolt. I lost one of my bolts so I went to an Ace Hardware and bought two new bolts, and the car is acting a bit funny now. So, are these bolts a problem...if they are, what type of bolts and where and type do I need to get. Thanx
Doug
BenSwanson
Nashville, TN
the bolt that i put there originally was not long enough to make a ground apparently
i think the shorter bolt was supposed to go over by the IAB
i put a longer bolt in there and it solved my problems
