Engine starts surging when warm
Ex3Cutioner8
Maine
hi. i have a 1995 sho mtx. it has new crank sensor cam sensor timing belt and i replaced the DIS Cleaned the Mass air sensor. the problem is when it is cold it runs really good, but when it gets warm i mean as soon as it gets warm, i will put in in 4th gear at 2k rpm and step on it, and it will surge or kind of buck like a bad crank sensor, the problem starts to go away at 3k rpms, the cel is not coming on, i have checked for vac leaks found one but it did not fix the problem ,and also it has a real rough idle for the past 4 months, the problems don't seem to overlap time wise but you never know, the bucking is new, i'm kind of lost on this one, any help would be great. Eli
nik97
Mile high
Try a known good MAF sensor. Cleaning a MAF can help if it is dirty but it wont help a bad MAF. I've recently seen a MAF swap fix this exact concern.
Tecchie
Marysville, Washington
Actually...............
:woohoo: I would take the Air Idle Bypass Valve (the thing on top of the intake that has a 2-wire harness connecting to it and has only two hex/allen wrench bolts in it) off and clean it, but test it first, has to read on your multimeter between 7 & like 12 Ohms... Mine was at nine, but dirty as all ****, so I sprayed some carb cleaner in it until I can see it was swimming in it, and that cleared alot of gunk out of it.....
I had the same problem but usually at idle, it would rev between 1k and 500k and sometimes low enough to make the oil pressure light flicker a bit...
Also, I get the same thing when it's hot and I press on the gas even at highway speeds and it acts like there is no power until I push the throttle to the floor a bit more and then it just lunges... :p
Hope that helped..
