Yes, I'm finally a member of this forum!
SHO members, I need your help.
Like it says in the title, somewhere in the engine, there was smoke coming out.
I'll start from the beginning.
1st problem car shut off. I thought it was the crank positioning sensor again, but it wasn't.
2nd The car started, but it sounded like it was really weak.
3rd My ignition coil melted. I replaced the ignition coil, and then noticed it started to smoke under the intake manifold (left side) near fuel pressure regulator.
4th Changed fuel pressure regulator because it was leaking fuel.
After I changed all these parts, the smoke still continued.
The car started to smoke when I put the key in the "ON" position. So, it has to be an electrical problem.
I took off the intake manifold, and that is where I am stuck.
I have tried to research everywhere (even on this site), but cannot find anything.
Please help, thank you.
If you need more info, please let me know.
