brian mcleod
95 mtx, engine idle is jumping around below 4000 rpm. It will jump from 2000 to 3000, it won't flow smoothly. This is a new problem, started last week.
any ideas???
any ideas???
Also, after you check your codes, you may want to reset the idle speed to see if that will fix the problem. Do a search for <strong>Idle Speed Reset Procedure</strong> and look for sdpatt's write-up.brian mcleod:
any ideas???
