Engine noise
Greg1991Plus
CA
I've searched the forums and checked all the usual things...
I have a tapping sound on a 1991 Plus, on the top passenger side of the engine---and it gets softer as the engine is revved harder and goes to higher rpms.
Rod bearings are recent and rechecked, main bearings checked out OK, both belt tensioners are not it, removed vacuum line to secondaries, not it.
Changed injectors to another set and no change, checked valve adjustment, all good, noise not coming from chain tensioners either.
I'm baffled---noise is most pronounced when stethescope is on injector rails.
I thought it might be timing belt tensioner, not sure, belt is tight and normal.
Engine runs fine, it's just an annoying noise that I can't get rid of. Looking to sell soon so I'd like to get this figured out.
Any ideas?
Thanks!
Greg
Sho_Freak
^^ Awesome!
Iowa
could it be a sticky or about to go injector if most of the noise is from the rail?
Sho_Freak
^^ Awesome!
Iowa
He tried another set of injectors with no change.
DUH! must have missed that part.........man, got some bafflers tonight! bearing goin bad on your timing belt tensioner?
Greg1991Plus
CA
Thanks for the response
So a 3.0 timing belt tensioner could make this noise?
It's holdiing the tension fine on the belt.
Sho_Freak
^^ Awesome!
Iowa
I can't find the thread but he had a video on his that seems to be a noise like your describing and I'm pretty sure a new timing belt tensioner fixed it.
Edit: his was a bad atx tensioner... I'd still pull the top timing cover and start it up to see if it is more pronounced/louder.
Greg1991Plus
CA
Put stethescope directly on tensioner and can hear the noise but I also can hear it at the same level through the water pump.
Tension on timing belt seems normal, could it still be the timing belt tensioner?
I can't think of any other source of this noise.
jonheese
Used-To-Know-It-All
Fogelsville, PA
Yes, it could still be the tensioner bearing. The tensioner still works to keep tension on the belt, but the bearing just makes noise as it goes bad.
The noise is not likely to be caused by the water pump, as they aren't known to fail in a noisy way (AFAIK).
