Mike93
Go Sabres!!!
Engine miss??? Updated...now calling those who have done the atx/mtx swap
Ok...where to start. I've been dealing with a problem that has been going on for about the last 10,000 miles and have tried many fixes and stumped everyone along the way, here's your chance to shine
I've pulled codes and found nothing.
Anyway, I'm pretty sure that I have a miss somewhere, feels like I'm running on 5 cylinders. I notice it most at idle where I get a pretty significant vibration that causes the dash to shake and the driver side headlight to wiggle (must be annoying to other drivers at night
) It will come and go, but not disappear, and is more of a fluctuation of vibration. While driving, it feels like I'm running at about 75% of the engines power. Cruising the higway it feels a bit smoother but still slightly noticable. WOT it will stumble and jump it's way up the rpm band, still pulls okay but not all there.
What I've tired:
*New plugs (Autolite 3924's) 3 sets now, gapped to .044
*New wires (AC Delcos) and 20k Motorcrafts
*DIS, coil, mass air from a parts car (known to be good)
*New fuel filter
*I've tested plugs, wires, and fuel injectors individually and all work fine. Plugs and wires were removed for testing...removed intake and plugged up a home made fuel injector testor that allows me to see the spray pattern. Injectors passed.
Wierd things:
1) Had a bad EGR valve, pumping a lot of crap into the intake...figured that was causing a problem. Blocked it of...nothing changed.
2) Pulled timing chain covers...two cam sprockets lined up fine, crank sprocket off a few teeth...figured this would be a problem...adjusted it...nothing changed. Unless I'm 180 degrees off on the crank???
3) Put a timing light on #1 coil wire and it would show spark to be 'on' for 5 or so hits and 'off' for 2...so it was missing, but not consistently. Put it on another wire (forget which one) but it sparked perfectly. So something wierd going on here...
4) Had a stock y pipe that came from the mtx parts car, I suspected clogged cats but can't determine if this was true. Anyway, I replaced this with a friends Sho Shop catted pipe and the car drove great, felt VERY strong and I didn't notice vibrations. Then, gave the pipe back and replaced it with a Summit pipe and vibrations are back. This seems strange that the car responded so differntly to differnent pipes...
I don't where to look next...thoughts???
) It will come and go, but not disappear, and is more of a fluctuation of vibration. While driving, it feels like I'm running at about 75% of the engines power. Cruising the higway it feels a bit smoother but still slightly noticable. WOT it will stumble and jump it's way up the rpm band, still pulls okay but not all there. What I've tired:
*New fuel filter
Wierd things:
