engine lurching need advice
KirkSHOcrzy
several times over the last 2 weeks i have noticed while at steady speeds that for no apparent reason the car will lurch or get jerky (like when you don't use the clutch at a stop) once or twice then run fine. It runs fine accelerates great and shifts fine. Hard or soft accelerations no problem. Just wondering if this is a mech. issue or dirty injectors. Gonna replace fuel filter and air filter this weekend. (less than a year old and only 2500 miles on them) also gonna see if i have oil in plug wells and clean if need be. Just wondering if i and missing anything else. 60k was done before i bought the car 5 years ago ( only 34k since) any ideas would be appreciated.
it is and 89 mtx 136k
thanks
Kirk
KirkSHOcrzy
Well i got a chance to look at the plugs and i think i found the problem. The front 3 were full of oil. i cleaned them out couldn't get to the back but i took it for a ride and no more lurching. Guess the 60k that supposively done actually wasn't. So if anyone in the denver area could get me a price on doing it i would appreciate it as i have no garage tools or ability. thanks again.
Actually all i probably need is valve lash and new seals. Had a bunch of work done not to long ago new crank cam dis belt. unfortunately had to take it to 2 different mechs because the first were idiots.
