engine light ?
93 Fo SHO
Hayward WI.
How do you pull codes on the SHO using a jumper wire?I can get them on my Iroc-Z but not sure on the taurus. My check enging light comes on when its warm outside I think. Cause I go to work in the morning (about 10 miles) it dosent come on but when I leave in the afternoon it comes on right away(within the first few miles).
J
Jeremy Hohn
Guest
Well, on my 93 atx, you take the EEC test module off of the passenger side firewall, unfasten the cover and look at all the plugs it will look like this
- - - - or someting like that... then take a regular wire and put it in the upper right part of the "pyramid" I like to call it, and jump it over to the test area in the corner of the assembly. Go to shotimes if I confused you....
Read about it here... http://www.shotimes.com/SHO3eeccodes.html http://www.shotimes.com/references/eecarticle.TXT http://www.shotimes.com/SHO3eeccodes3.html
Jeremy
1993 atx 122k miles
-PIAA headlamp bulbs (thanks Fratperformance)
-fish tanks installed
-fog lamp mod w/ blazer fog lamps
-6" 5% tint border on windshield
-black body filled lettering
-wclewis "powered by yamaha" badges
-Sho Shop Cold Air Induction Kit
-Lund blackouts front and back
-cincysho colgan half bra with "SHO" lettering
-KVR chrome cadmium plated rotors with carbon fiber pads
-Sho Shop cat back system with magnaflow chrome tips
-Performance Plus y-pipe
-TX personalized plates "SHO FUN"
-Shoshop underdrive pulleys
-Shoshop 80mm MAF
-60k completed by Sdpatt
-Redline atx tranny fluid and water wetter
[This message has been edited by Jeremy Hohn (edited 11-05-2001).]
