Engine Light on and off with power loss
gregor
Salt Lake City
92 MTX with engine light comes on with loss of power to what seems like running on 3 cylenders. Light goes off and power returns???? I have swapped out the coil, so I know it isn't that. This happens intermitently, with running OK most of the time.
Took it in to put on the computer and codes had coil code (wasn't that) and several dirty mass air flow codes. Could it be as simple as a dirty mass air flow? (Next project)
Anyone have any suggestions for what else could be causing this?
Thanks,
Gregor
frosho
WOLFMAN
Tyngsboro, MA
My bet is the DIS (the gray plastic thing on the pass. side of the intake) went bad, but definitely clean the MAF before you try swapping parts out.
gregor
Salt Lake City
Thanks,
Should have thought of trying that myself. I cleaned the MAF and only had the engine light come on once for about 10 sec. So far, so good, but will try this if it comes on again.
Thanks,
Gregor
Post your exact fault codes for better diagnostic assistance. Without them, all we can do is guess.
Storm-Chaser
Shit Louis
If the problem continues, also look at the cam sensor (CID), which should set a 211 code. Next time it happens, look to see what the tachometer is showing (no change, rpm loss, zero rpm).
:burnout:
gregor
Salt Lake City
Thanks guys, it was the ECM
Thanks guys, it was the ECM!!
Gregor
:thankyou:
