JTM
i just put in a new thermostat, a new radiator new belts, and a new battery. the fuel guage doesnt work.. and the thermo guage has only worked once since i got it, the fuel guage didnt work when the temp guage worked. i changed the oil it looked clean, a LITTLE cloudy but i think there may have been an additive in it. so heres my problem
first i cant find the fuse box (havent taken anything apart but i looked under the dash and on the sides of it and in the glove box.. no go)
second the engine knock, dont know why but it does.. what r some common issues with this.. and it may have been due to overheating as the previous owner jacked the car up using the radiator support (it was all bent up and smooshed the bottom 1/4th of the rad) i cant see any other reason for the car to be damaged in this manner.
third the car overheats, when the temp guage worked (for WHOLE DAY) it would slowly make its way up to N the fan turned on and the needle KEPT climbing... the the heater would not blow hot air.
fourth the gas guage doesnt move.. i filled the tank with gas.. the light is on (orange gas pump light) but the needle sits on E.. ive read that the gas guage and the temp guage share a ground where is it?
fifth the door code for my car is on the trunk lid, so i got it (after having to figure out how to open it with no key, i finally popped that button up on the side of the drivers seat and was able to pull the ltach up) its "77206" so i have my wife sit in the car and lock the doors.. the dome light turns off and i begin entering the code.. the dome light comes on when i press the first button but the code doesnt seem to work.. after i enter in the code... what am i supposed to do?
and help would be greatly appreciated.. thanks so much.
hey an dif anyone lives near Fresno, CA i would sure accept any help i could get.. even if we just hang out scratching our heads @ this car.. thx again
