engine knock
slow99gsr
tx
93 sho
when i start it you will hear nothing but after about 5 min of idling the knock gets loud and when you give gas it speeds up with motor. now i havent been 100% able to pinpoint where it is coming from but i believe it is (when standing in front of the car it is on the left side of the motor. anyone had this same problem?
F-22 Raptor SHO
7015 feet above Sea Level
taking a wild guess, I'm going to say you have an automatic, then I will guess again and say the knock is on the left side (passenger side) in the back, then I will defy all odds and say the knocking goes away as you rev the motor past 2500 rpms, and returning as the motor slows down.
If this is the case, you have a very common problem: a bad timing belt tensioner. The belt gets just slack enough to cause the #1 cylinder to knock badly.
slow99gsr
tx
is it possible it would not do it when it is cold but upon warming up??
how much are these pullies running ($) ?
INDO SHO
california
Are you shure that the noise you hear is a knock (pinging, knock, chattering) try using a higher octane of fuel.
wood_e
The dude
Ames, IA
I'll be the first to say rod bearings..... but we're missing the mileage of the car
