engine is whining .....still
xxtattootearzxx
pennsylvania
AHHHHH. somebody help! lol . ok here it is . just bought 94 atx . dont know if 60k was done or 100k for that matter . here is what i know . 1 yr old transmission , new altanator ( previous owner replaced thinking that was where the whining was coming from ) car has only seen 2 winters . 147k on it now . i just replaced power steering pump on sunday thinking thats where the whining was coming from...... no luck . 2 mechanincs said it was power steering pump ....obviously they were wrong as well as i . the noise seems to be coming from the one of the pulleys . it is loud when idling and very very loud when driving . any guess's gentlemen?
any guess welcome
XxTaTTxX :hail:
sho_me92
it`s SHO time
utah
idler pully ...my old sho made a whinning sound i thought it was cool cause it sounded like a supercharger lol ..but ckeck your idler pully :thumb:
sho_me92
it`s SHO time
utah
humm im not sure on a atx cause thay only have one belt but the 3.0 have two belts so they would need two
xxtattootearzxx
pennsylvania
just from directions from the power steering pump there was 2 pulleys ( not that i counted ) one was drive belt other was ..........who knows what
xxtattootearzxx
pennsylvania
maybe i should just pay sticky for his time and his opinion ......... how do i get his attention? ..... curse? no that wont work ....... beg? no even worse..... i kno direct deposit check to his paypal accont? lol
TicoSHO
93 in Largo, FL
Largo,FL,USA
I had a similar prob and I thought it was the Alt too , but turned out to be the idler pulley.
It sounded like a very small but very loud s/c.
xxtattootearzxx
pennsylvania
where can i get an idler pulley? i remember reading a thread that said they where to get it for a gen 2 but it was like 120$ ...... then in the same thread someone posted that you can use an idler pulley from a gen 3 and it was only 15$ is this true ? and if so where can i find it?
ohfosho
ontario SHOwner
ontario, canada
well it is very easy to diagnose which pulley it could be. all you need is a full can of WD 40. spray on the pulleys that you think could be probable, and the noise will go away momentarily while the bearing is lubed.
i wouldnt be supprised if it is the waterpump...
xxtattootearzxx
pennsylvania
just playing it by ear it sounds like its to the right of water pump . and to left of altanator .......... could be idler pulley ........ but there is another pulley directly under that one . not even sure what that pulley is at this point.
Sho-N-Go
Indiana
It is the lower ldler pulley it is the one that typically goes out. Ford still has them availible for I think around 100.00. I also have a few laying around. It is the lowest pulley. the bolt head is 14mm. Good luck
SuperHO
Mental Patient
St. Joe, MI
Take a long extension or something....touch the nut in the middle of the pulley with the extension while the car running and hold the extension to your ear...you'll know when you find it.
ohfosho
ontario SHOwner
ontario, canada
when to **** the 'actual' waterpump pully, you would have to aim the WD40 right in towards the timing cover...the pulley that the belt is on is more like the 'drive shaft', or an extension to the actual pulley...so try getting it right in there. but if you havent had the 60K service done, i would be thinking about that.
LeddZepp8687
The Keg Rider
Naperville, IL
My ATX makes a slight whine at idle and I could SWEAR that its the alternator, also the whine pulsates and the headlights and all other electrical components dim in and out in sync with the engine's pulsating whine. Ive got a lifetime warranty on this alternator so I might as well get a new one.
DigDeez
Chicago
Yeah, I sprayed some **** on the pulley and got a response whereas the whining noise momentarily disappeared. I'm not sure which pulley it is, but it's the closest one to the firewall, which seems to be the biggest of all the pulley. This one is call what?
Mine is very loud, and smoking! What's the labor time on this job? Thanks!
