Im in the process of building my 3.2L and should be done fairly soon now that i have all the correct parts. I am in the Engines program at Fox Valley Tech College in Appleton WI. We have a dyno that people can use for a few pulls with their car. Its $90 for 3 runs, and you are allowed to modify things inbetween each pull. If anyone is interested and lives in the surrounding area dont be afraid to send me a message.
My plans for my 3 pulls....
Engine will be at normal operating temperature with Mobile 1 synthetic 5w30.
Exhaust will be Y pipe but nothing after it.
A/C has been deleted, so there is no added friction from the compressor.
1st Pull
acurately measure the torque and hp with the secondaries ALWAYS open. By this i mean hooking them up to manifold vacuum so they are never shut.
2nd Pull.
return the secondaries in the intake to NORMAL operation. this should put any myths for HP and Torque readings to rest. Thus we can accurately see the difference from the two pulls. This should solve multiple questions and theories about which set up is better
3rd Pull
The real difference between a stock Y pipe (which i currently have) versus the aftermarket high flow Y pipe. Since my engine build is quite extensive, i dont have the money to buy an aftermarket Y Pipe. I would be more than willing to change it out if someone would borrow, or sell me one for cheap (highly unlikely).
If there are other things you would like to see the difference of between pulls 1,2 and 3, please comment and let me know. I was also thinking about the air induction system (N/A) and how much power would be gained by going to a CAI or Ram Air induction system. Another thing as i mentioned before is the A/C Condensor Compressor. If someone has a junk one lying around and would like to borrow it, to see the added difference of an A/C delete, let me know.
Anything else just post. This may have, or may not have been done before but im willing to put these 3 pulls to good use.
1st Pull
2nd Pull.
3rd Pull
