Engine Dead, Can't pull codes
slapnpop
Johnson City, TN, USA
'95 ATX
Long story short, the engine died at a red light today. Only a 1/2 mile home I pushed... :dribble:
Anyway, I can't pull codes. I have the connectors, I jumper them, the same way that always worked on my MTX, but no codes come out. I suspect there may be a break in one of the two wires along the way.
Is there a way to jumper at the ECU or some other "up stream" location directly?
n8rsk8r
Hey Where's my post?
Olathe, Kansas
I wouldn't do that personally. Check all your connections man. That will be your best first step. Clean em and tighten em down. Good luck to you man :thumb: Let us know what you find out. :)
projectSHO89
SHOless In St L
Check the 10A IGN Coil fuse in the under-hood box.
If blown, disconnect the electrical connector on the coolant overflow tank before replacing the fuse.
Steve
slapnpop
One of the two wires had a break about an inch up from the connector. Jumper the two wires directly together upstream of the connectors and she spits out codes.
