+SHO-
Im sure this will be easy for someone out there with the same problem in the past.. My 95 SHO will usually require 4-5 seconds of crank time before starting. In addition, while driving I will sometimes feel the engine miss a beat and set the check engine light on. I did a complete tuneup and fuel system cleaning. Im told the cam or crank sensor can cause either problem but cant remember which one. The last time I pulled the code it said one of the o2 banks was running lean.
Any ideas much appreciated....
