gamefanatic
After replacing all my hoses, pump, accumulator, and even the radiator with new stock parts I have seen very little improvements. Where I am at these cars are struggling to keep cool when it gets above 100°F, which is low for us right now.. Need to bump it up the cooling capabilities to the next stage so I can make the climb up the hill with no worries.
Have any of you messed with upgrading to a cross flow or a dual pass system? I have seen some mention using an electric water pumps, but do they spin the pump any faster? I am thinking the pump is efficient enough, but maybe getting a 4" camshaft pully would improve things a bit? I lack experience with this tech to know what might work the best.
Right now I am working on setting up evaporative cooling using the wiper fluid tank, mostly since there is button for it built in... Yeah... I know, the windshield wipers turn on, but once I have it all setup, I'll fix that... I have it rigged right now to spray on the condenser, but think I may try to move it so that it sprays right on the radiator which may require some precise locating of the sprayers...
