Engine coming out again
Johnbigdog
michigain
I bought an alldatadiy subscription for $30 and have used it for most of my repairs. Well worth the money.
Sent from my SM-G965U using Tapatalk
You can also buy a workshop manual DVD from Helm that also has wiring diagrams for your car too if you want it to keep and not keep paying.
FAMOVER
New England
Did you have any trouble separating the engine from transmission? I am trying to swap my transmission right now and I have the subframe on the floor like in your pictures. I think I got all of the bell housing bolts out but it doesn't seem to want to come off. I am trying to remove the transmission without removing the ptu because I believe I have all of the bell housing bolts out around it and it would be much easier getting the ptu off and switched to the new transmission once its separated from the engine. I also can't seem to get to 1 ptu bolt without getting the bracket off and I took all of the bracket bolts out but it does not seem to want to come out so I decided to try to pull the transmission with it still attached. Maybe I need to completely remove that turbocharger bracket?
I have been doing my best to follow the transmission removal procedure from the Factory Ford workshop manual. The workshop manual assumes you will remove the transmission by lowering it down from inside the car and I like you have the whole subframe engine/transmission assembly down on the floor so not everything is the same especially access beneath the subframe. I took the whole thing out because I needed to replace my waterpump as well. I'm on the home stretch here but I'm struggling getting this transmission off a lot more than I expected.
mrhighcaliber
Remove the ptu first, trust me.
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
I would hope that for the new transmission even with the low mileage you did some pro active steps and R/R the Transmission Filter. The fluid itself may be recommended to be changed every 30K but since your doing all that work seems like a new filter yes I know it is encased in the transmission housing but doesn't sound like much extra work to get a good starting point of new filter and fluid.
Cracking the trans housing in half is a job for a seasoned mechanic/pro. New fluid should be enough.
crystizel
