engine codes help
laxmax327
philly
211 (M) Ignition PIP signal was erratic or missing - Ignition Systems
542 (O,M) Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
the other day my car just wouldnt start when i went back to it in the parkin lot. drove fine 30 min before. then we randomly heard a click under the hood and everything was fine. some sort of relay. then on the way home. the car stalled out while cruising and the cel light flashed. the cel light is never on. but those were the 2 memory codes that i got today. its been driving fine since.
SeanMc
NoMoSHO
Crank position sensor, and probably a bad check valve on the fuel pump. Have you cleared the codes and ran them again?
