Emmissions Testing Failed Twice
Patrick Norris
I need to get an Ontario E-test on my car to register it. It failed
1st test I changed
both o2s
thermostat
plugs
cam position sensor
2nd test I changed
ECT
Still no pass it fails on the NO or NOX. I can't figure it out. Normally this is the gas taken care of by egr but since I have no EGR I don't know what to do?
I also am still having issues with the coolant guage. Is it possible for a parts store thermostat to be bad in 2 weeks? BTW I would have used a ford part but they have to order it and I didn't want to wait.
Any ideas?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
High NOx means the car is running lean. Surprising since you've got new oxygen sensors.
Wait, its not surprising, you've got a K&N filter. Clean your MAF, the K&N oil is probably coating the filaments, causing it to run lean.
Patrick Norris
What causes the black soot on the tail pipes? Rich or lean?
Rockledge
Pluggin' away
Connecticut
Have you thought about pulling the spout connector for the test? Retards (defaults) the timing to 10* BTDC, which in turn could help bring those NOx numbers down.
CheckerSHO
Ford Employee
Acworth, GA
thats a good idea on the spout connector :D I'm in the same boat with my SHO...high in NOx. Hope a pair of 02 sensors and a MAF cleaning will fix er' up :****:
Patrick Norris
I could but I think the car should pass the test without doing that. If some guys can pass with a catless y pipe I should be able to pass with cats and good sensors.
