Eibach/Stock shock?
skippie
Monroe , MI
I was wondering if its ok to buy the stock replacement shocks for the SHO, and then just put some Eibach lowreing springs around them, and put them on the car? has anyone tried this? how does it ride? :confused:
shojuan
sunny San Juan Bautista,
I would consider the KYB GR2 to be the minimum strut that I would put on an Eibach. I wouldn't even bother buying Eibach's until you can upgrade from the stock struts.
Rick
RI-SHO
B to the BANNED
Pawt., RI
From what I have read the Eibachs can be pretty cushy compared to the KYB GR2's.
If they can keep up with my "lift off the ground rear-wheel" tight springs for 2years then they could handle the Eibachs, especialy if you do not AutoX etc.
shojuan
RI-SHO:
Are you referring to the stock struts or the GR2s?
Rick
1fastsho
Athens Ga
the stock struts do not really have enough rebound deigned into them to work well with anytype of performance spring. What will happen is it may be ok at first but it will wear the strut out quickly and then it will ride like a pogo stick
shojuan
skippie:
I think we're all in agreement here that it would be a mistake to combine Eibachs with stock replacements. If you're after a stock-like ride and you've decided to replace your stock springs with Eibachs, you would probably be very happy with the Eibach/KYB GR2 combination. Even though the dampening of the GR2 is a little bit firmer than the stock strut, because the Eibach is progressive and is initially quite soft you should end up with a comfortable, yet more controlled ride. I wouldn't be surprised if you found the combo more comfortable than stock, yet surprisingly controlled through any kind of turn or corner.
Rick
drivinhard
Gainesville, GA
You'd be better off sticking to the stock springs, and going with struts with more rebound control.
Especially with early MTX springs, the SHO has always needed more damping in the stock struts. I ran tokico's on stock springs for a bit, and it was a great combo.
<small>[ November 07, 2002, 09:41 AM: Message edited by: drivinhard ]</small>
gosho89
Vancouver, WA
skippie, don't do it.... your car will have a pogo stick type ride with in 10k miles. The stock struts can't control the rebound of the aftermarket springs. Take it from me I tried this on the wifes 93 atx car and ended up installing tokikos a year later and throwing away the motorcraft struts.
96lt1
Likes to cut
Ashland, Ohio
who sells these gr2 shocks and how much r they?? i am in dyer need of a suspension system right now. just bought a car with the right rear spring and shock missin
skippie
Monroe , MI
Well, I guess I'll just wait and save up and get the Eibach's with some good shocks. I was just hoping I would save a little dough going with stock shocks. But I guess that would be a bad idea. And yeah, I was looking at the GR2's on tirerack too RI-SHO. thumbs_u
FordLover
Houston, Tx
skippie:
Save the money you were gonna spend on the eibachs and spend it on struts. you'll get more driving enjoyment from the struts than the springs.
-Martin
skippie
Monroe , MI
ok...im confused...If I get eibach's with a shock, that is a strut isn't it? If not, i am missing something here....there all just coil over struts right?? :confused:
RStalveyARFF
too many shos
Georgetown, MA
shocks are totally different than struts. The sho does not have shocks, it has Mcpherson struts on all 4 corners. Normally, you will see struts on the front of a car, and shocks if it is a live rear axle or struts it it's IRS, but there's always exceptions to that.
<small>[ November 11, 2002, 07:49 PM: Message edited by: SHO91MTX ]</small>
Nook
SLC
You will get a bit of pog-stickign with the Eibachs and stock struts.
N
The struts are from multinational companies. I think if you know the product you're looking for you may find distributors on the European Continent somewhere. Would shipping from here still be a less expensive option?
thatSHOguy101
