EGR valve replacment
skippie
Monroe , MI
hey guys, i am putting on a new EGR vavle, and i cant seem to break loose the 15\16's nut on the bottom, do you know if heating it up will help break it loose? because i dont want to put to much stress on it....thankx
Mike/Milwaukee
Milwaukee, WI
Skippie,
Be very careful!!! I changed mine out 6 months ago and it broke free right away, but my car was from N.C. driven to WI. No snow and rust!!! Spray the dam thing good, but don't drench it!!! Let it sit for a 1/2 hour or so and then try. Heat is not the best-It's an aluminum engine. If you have to use heat not very LONG at all!!!!! I hope this helps.
Mike
As said before, spray it well with penetrant. Heat shouldn't be a problem if you remove the entire EGR line from the car. There are two 12mm bolts that hold the bottom ****** to the number 3 exhaust manifold runner. These can be accessed from laying on top of the intake manifold and reaching down and around the back and rear side of the engine. I had to remove ACV1081's EGR line when we found the weld breken at the ****** during his valve gaping job.
skippie
Monroe , MI
Alright, thanks for your help guys, I drenched it like a ***** with wd-40!...and after prying on it with a darn pipe wrench, it finally gave way!
jcostantino
Coral Springs, FL
Easy way to test... put a length of 1/8" vac tube on the ****** that's on the EGR valve. Apply a vacuum to the tube (suck on it) and your car should run VERY poorly while the EGR is engaged. If your idle is unchanged, try to return your new $55 egr because it's in good condition and you need to clean your manifold.
jeff
