EGR VALVE 332
joesho24
Waterboro, ME
I had the car diagnoced. its a code 332 the egr valve not opening deteceted. Replaced it not the check engine light is still on. Do i have to reset my computer? Or is there possibly another problem
Mr Anonymous
Tire Wall
Chances are the old EGR valve was fine. The 332 problem generally arises when the EGR plumbing in the intake becomes clogged with carbon.
You'll need to clean out the EGR 'nostrils' in the intake. If you search the forum for nostrils, or 332, you should find various methods for doing this.
blue30balls
New Jersey
But did you get in the EGR ducts? I had to do this about a month ago, it pas packed solid with black garbage...as it is exhaust going through a tiny little tube.
Go here....and do it, it look me in total about 40 minutes, mostly cause i'm kinda **** about when cleaning something, clean it right.
http://www.shotimes.com/php-bin/modules.php?op=modload&name=News&file=article&mode=thread&order=0&thold=0&sid=86
I found that mine was so gunked up i needed a small length of wire to help poke through enough just so the cleaner could seap through.
projectSHO89
SHOless In St L
SolidState:
as noted in steve's trouble shooting guide, clean the EGR nostrils out well...
mine turned out to be a faulty DPFE sensor...
The point of my troubleshooting guide was to find out what is causing the 332, then fix it insted of stabbing in the dark at likely targets.
I had wasted a half a day on pulling that 94's intake only to find there was nothing wrong with it. I also found the problem to be a DPFE. That is why I wrote the troubleshooting guide since most suggestions for resolving this code blindly recommend the intake cleaning.
Steve
joesho24
Waterboro, ME
what exactly is the DPFE sensor? is that the sensor that the vacum line runs to off the egr valve??
projectSHO89
SHOless In St L
joesho24:
No, please go read my troubleshooting guide. Please also go read the tech bulletin article I provided.
The component that the vacuum line connects to the EGR valve is the EVR (EGR Vacuum Regulator).
Steve
<small>[ March 04, 2004, 02:01 PM: Message edited by: projectSHO89 ]</small>
dustin
'93 SHO Owner
Orange, CA
projectSHO89 said:
Before doing anything else, click <332 troubleshooting> and follow my instructions.
Steve
The link does not point to the article anymore and search doesnt find it :( I have this issue right now with my '93 ATX. Any help pointing in the direction to this guide would be appreciated thanks.
jedhead
westminster,ca
Steve
That may be true, but I haven't seen any intakes that didn't need a good cleaning except mine EH intake. The gunk doesn't seem to stick to the EH intake.
Bob
David Carpenter
