I need help guys, and you have always come thru for me in the past. I am getting the 332 code and my passages are clean, new EGR, I can apply vacuum to theEGR at idle and the motor runs rough, so the EGR can work if the vacuum valve that controls the ERG would open when it is suppose to. I have a '92 MTX and have tried the suggestions that have been posted, to no avail. The one post that was the most detail, was for a 93 and later ATX...it did not help. My question deals with the valve that controls the EGR, there are two wires that go to it and they read about 12.0 V at idle. Should the voltage drop to open the vaccuum to the EGR, I know that the EGR is not open at idle or WOT, But should I see it open by increasing the engine, with the car stopped. If so, I don't...What else controls this valve... I have swapped a valve that worked off a different SHO and replaced all the vaccuum lines, still I get the codes... Please help, anybodies insight on this would help.
Thanks
Thanks
