Ect help
shoff22
missouri
How to you get the ect in the back I took off the throttle body and every thing off already but now theres a harness in the way so i cant get a wrench on it any help would be great
Ishodu
What are you talking about? The coolant temp sender? The upper one (1 wire) or the lower (2 wire) one? If you can't use a wrench use a deep socket.
msteiny
Grand Forks,North Dakota
One inch deep socket. You can get to it with a open ended wrench. I changed mine out last weekend due to a code. They dont need to be crazy tight. Took a whole 5 minutes, I didnt remove anything, I didnt even drain the coolant I just swapped it out quick.
shoff22
missouri
I cant get to it with an opened end wrench there is 2 harnesses grosin g over the tom of it and there tight and wont move out of the way but ill try again what size wrench is it thanks
itwonder
VA
On my car, the harness pigtail to the ECT was twisted in a way that made the harness very tight (probably from the factory that way). Once I got it disconnected from the ECT and straightened out, I used a piece of wire run vertically up through the intake and secured to pull the harnesses out of the way while I used a 1" socket to remove the ECT.
