I have catch cans on both my G8 Gt's. Do you have a diagram as to where to put a catch can on EcoBoost engine. Mostly need the location of inlet and outlet locations on engine, as I can get enough hose and find a suitable location for a catch can.
Also looked up the product from BG and articles on cleaning EcoBoost intake system. When I attempted to look up the part numbers on their site, couldn't find any prices or data.
I pulled off the beauty cover and saw a flat plastic pancake looking component sitting on the rear valve cover, passenger side, seated in the valve cover itself. I think this is the OEM catch can. As it fills with oil, it will overflow back into the valve cover itself, a very ingenious design. Coming out of the top of this component is a solid plastic line that goes to the throttle body. I'm not positive, but I believe the PCV is on the throttle body itself. Given the car already has the catch can, I was thinking about adding an inverse oiler (http://www.ampcolubes.com/index.php?content=products) to the PCV system to feed a low dose of cleaner into the intake. Could be water, Lucas Fuel System cleaner, Marvel Mystery Oil, Techron, Sea Foam, gasoline, etc. It strikes me that by adding one of these cleaners could go a long way to keeping the intake clean.
Thoughts?
