eatc
sho4life
midwest
If my heater dosent change temp is this what I replace|? seems like it blows to fast on lowest setting too
jelloslug
Digital
Greenville, SC
Sounds like a blend door actuator problem for the temperature and a blower control module problem for the blower speed.
sho4life
midwest
where is the blend door actuator? dont even know what it looks like. I have a spare bcm, thanks
sperold
Last to Know
When your blower control module guits, you only have the high fan speed.
Do the numbers change on the read-out when you punch in new ones?
Go to the ShoSouce webpage and you will see pictures of the part, depending on the year of your car.
The blend door usually fails in the mode that allows your heater to work, just no mixing of cold air to give you different temperatures.... but that is usually.
sho4life
midwest
numbers change, i guess ill have to read up on that air blend control. this is my winter sho so not too worried about a/c.
