firstgen89sho
former Slo_SHO
Alright, wondering if any of you have run across this problem yet!
I have EATC (well, just converted over to it), and just having charged my a/c system to R134 after not having it charged since I got it. I have been having intermittant a/c problems. at times the A/C system will work fine, and others, it will just blow warm air. preformed some troubleshooting, and found that at the pressure switch, when the a/c is blowing warm, that I will have no power from the EATC, made a jumper wire to come from the eatc to the pressure switch, to make sure that there is no breaks in the wire, and also checked that the rest of the system works, by giving power into the pressure switch, and it turns on properly.
so when finding out that I have no power at the pressure switch, and following back to the eatc and finding no power, went and hit the EATC..... and the a/c kicked on...... went off again..... hit the eatc.... went on again...... I'm guessing that inside the eatc, that there is a relay that is used to turn on the compressor, that must be dirty?
what do you think about my assumption and possibility of fixing the problem?
