Easiest way to drain the radiator?
Silver Bullet
Corpus Christi, Texas
I am planning to change my engine coolant temp sensor, and I have read that the coolant in the radiator needs to be drained previous to replacing the ECT. What's the easiest/best way to drain the radiator? Can I just undo the hose that goes from the radiator to the thermostat at the radiator side and let it out?
yamahaSHO
E85 whore
Arkansas
There is a "petcock" on the bottom of the radiator drivers side... loosen and the radiator will drain.
In this picture, you can see I have a clear hose hanging from mine...
<small>[ February 16, 2004, 04:52 AM: Message edited by: yamahaSHO ]</small>
David Carpenter
