masho95
got Zex?
Just a quick question on how the e-brake works. Recently my e-brake has not been releasing, almost at all. You would have to manually pry the spring and cable back out to release. Does the e-brake rely on the slider pins moving to get it to release? The reason I'm asking is because I found that side of the rear brakes the slider pins were completely frozen up. There pretty much nothing left of the inner brake pad and the rotor was toast. So I brought all the new parts for that side and was going to change out all the pads in the rear. Just curious if fixing the sliding pins would also fix the e-brake. Thanks if any of you know. If not perhaps the e-brake is just binding up inside itself.
