E-bay indglo's!!!
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
Has any body else bought the indglos off of e-bay?? I am really not happy with them.. They are a little to small. and the holes on the gauge for the needles is way to big!! Any body else have this problem? I am just wondering.
Thanks
nothingtoseehere
I didn't get the indiglos, but I did get the Halos from e-bay and they fit almost perfectly. The hole for the needle is just right so as you don't have to remove the needle and the gauge face is exactly the right size. The only problem is there is no hole on the right side of the tach for the pin. SO I just took the pin off all together. If you like the look of the Halos the were only 78.99 after shipping and everything.
ShoGuy93
Did u take out the lights in the console for the gauges? Cause i am getting light coming from the edges of the gauge. and then light coming through the holes for the needles... :mad:
marlonius
Holden, MA
ShoGuy93:
Thanks
Try some of these:
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=23;t=000160
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=23;t=000140
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=22;t=000586
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=20;t=000562
Some people have had similar problems/complaints and others have had good luck. You might find some good answers in these.
ShoGuy93
Ok i got another ??? here do u take the factory black gauges out? Or do u put the inglo's over them???
if so i took my factor ones out. I think that may be my problem.....
nothingtoseehere
I left the factory black gauge faces in and put the Halos right over them. Did not remove the lighting either. I do get a LITTLE bit of light from the old setup, but nothing major at all....and actuall it doesn't come thru the edges at all......mainly a TINY TINY bit on the edges of the odometer and trip meter. I mean VERY miniscule too.
marlonius
Holden, MA
RCADDELL:
Same here. Actually, most of my bulbs had already burned out. I think only two are still good (one in the middle which light the odometer and speedo needle and the one that lights the fuel gauge). I too left the black gauges in place and put the indiglos over.
ChrisR
Las Vegas, NV
If you are getting too much light coming through small cracks, just turn your Factory dimmer down a bit to lessen the light.
ShoGuy93
Thanks a bunch guys i got it working just fine now. And it looks awesome now. I put the old black faces in and then put the inglo's over them.
Thanks again
marlonius
Holden, MA
ShoGuy93:
Thanks again
One more thing, a lot of users claimed the gauges have burned out. Most of them also stated they kept the gauges on full brightness. I have kept the dimmer at a little less than half and have not had any problems for almost three months. Just a thought...
