SHOfun 93
Well I took the 95 to the dyno with the 80mm/TedB combo also with the EH/BBB installed (still stock exhaust...slow a-- exhaust shop) and this is what I found out
yep that is a PIG rich 11.7 on the a/f. Ted said that will be a bit more lean when I scrap the 1.75" exhaust and install the 2.5 all the way back.
Compare that to the BONE STOCK dyno graph and I am up nearly 20lb-ft on torque! Can't wait to get this thing tuned correctly! :****:
Notice also the better spark curve with swapping to Vitek wires and new plugs.....
I will redyno next week after Ted's reburn and we shall see then! SHOFUN2 is on the PROWL!
Also Ted asked why they only did a pull starting at that RPMS, and I called the dyno guy and he said that it was cuz it was wanting to downshift. Should I do the entire pull in 2nd next week? or what?
