Marccus
(A) I'm trying to replace some of the sensors/senders in my '89 SHO. So far have replaced the O2 sensors and the coolant sensor for idiot gage on dash. Have shop manuals, but they don't do a good job of showing where the sensors are.
I'm interested in knowing the locations of the following sensors before I crawl underneath her (her?):
(1) ECT sensor
(2) Oil sender
(3) Oil level - idiot light on dash (?)
Is (3) at the front of the oil pan to the upper right in reference to the oil plug (looking towards front of car)?
(B) Where are jack points for SHO that are used for supplied scissors jack? I've been using what I believe are the correct locations - the indentation where the sheet metal is bolted together that runs the length of the car (I hope I'm using the right words and explaining this right).
(C) I have been using ramps to work under the engine. Recently purchased jack stands. Can I use the scissors jack to lift one side to desired height, place jack stand, then lift other side and place second jack stand?
I don't know if this is even feasible and how I can do this since the scissors jack will occupy the jack points. If this procedure is OK, is there another place to locate the jack stands besides the jack points or is there another place I can lift vehicle with scissors jack and then place jack stands at jack points.
Is there a maximum height I can lift one side in reference to the other side? I was thinking of going back and forth between the two sides and lifting each a reasonable increment to get the car at the needed height.
Is it dangerous to lift one side of the vehicle at a time like this and should I, instead, use (and need to buy) a hand floor jack (lift front of car at center and then place jack stands)?
Thanks for your help. Any assistance is greatly appreciated.
(1) ECT sensor
(2) Oil sender
