I started work on dropping the subframe out of my 92 that hasn't ran in 10 years. My goal is to pull the quaife'd trans out and stick it in my 91 that destroyed something in the driveline. I'm not sure if it's the clutch, PP, or TOB, but something went wrong. Anyways, heres a few pics with questions to follow:
I pulled the upper coolant hose and found this. I have no clue what it is.
Inside of the upper hose.
Contents of the upper hose.
My stopping point for the evening.
So my big concerns are do I need any specialty tools after this point? I d/c almost every connector I saw, pulled the intake, and evacuated the freon lines.
So where I'm kinda stuck is I couldn't really get the clutch cable off, and how do you d/c the fuel lines? I'm planning on dropping the suspension and brakes with it too. I'm doing what I remembered from the "how to drop your subframe" thread but forgot to check it whilst consuming beers and tearing things apart. The car will be stripped of all useful parts and sold as a shell to whoever wants it.
