1993MTXSHO
Its a Taurus...
Hey guys I was going to drop my oil pan becasue my 93 mtx is burnign liek 4 qts of oil every 3k. I just want to make sure its clean but is the oil pan gasket reusable or will i need a new one?
SLoW_SHO_316 said:You *should* be able to re-use the end seals, but you'll need to clean off all the old RTV and then use some new black RTV to seal it back up.
My question would be, if you're burning oil, why would you want to inspect under the oil pan? Sounds more like a piston rings/valve seals thing.
yeha mine definitly burns to much oil I think its the valve seats or seals although i guess my car being raced it whole life could have bad rings too.LeddZepp8687 said:Im leaking some oil, But it doesnt seem like alot, However I have had to add about maybe 3/4 of a quart of oil over that past 3 months..Im hoping its just caused by the leak and not bad rings or valve seats/seals....
1993MTXSHO said:Hey guys I was going to drop my oil pan becasue my 93 mtx is burnign liek 4 qts of oil every 3k. I just want to make sure its clean but is the oil pan gasket reusable or will i need a new one?
its not smoking at all from the engine compartment, I think its been this way since I bought the car. You dont notice smoke unless your under WOT but its burning/leaking oil 4 qts to the 3k mile mark, which is a lot to not have visible smoke or a visable leak if you ask me. The car seems really clean on the underside, so im really confused on why its consuming so much oil.Shuey said:Make sure the rear valve cover seal is not the cause of the leak, it might be leaking onto the exhaust manifold instead.
pjtoledo said:If your oil filter is working properly that restore stuff isn't going to go very far. What oil are you using? Synthetic oils can blow thru a worn engine real fast. Try a heavier weight regular based oil, you may see a big difference in consumption. For hi mileage engines I use 15-40 truck oil. Great for the summer, too thick for the winter.
Perry
That Restore stuff actually worked pretty well in my 91 mazda truck. Though that truck had a really low oil pressure problem (needs new main and rod bearings. A lot of 4X4 stuff in the way of the pan makes me lazy) and scored cylinder walls. The truck went half its life with a vacuum hose for the remote freewheel dangling near the ground sucking up tons of dust, dirt, and sand. It spent as much time off road as on as a geotechnical engineer's work truck. Having lost several cylinder heads and having piston seizure the last time a cylinder head went didn't help. Neither did sitting for 2 years with milkshake oil in the pan before I put on a new head. So for that vehicle the Restore worked great. I stopped using Restore when I ran some Auto-RX through to clean things out and the Auto-RX probably cleaned the restore "CSL" stuff out too.pjtoledo said:If your oil filter is working properly that restore stuff isn't going to go very far. What oil are you using? Synthetic oils can blow thru a worn engine real fast. Try a heavier weight regular based oil, you may see a big difference in consumption. For hi mileage engines I use 15-40 truck oil. Great for the summer, too thick for the winter.
Perry
dantheman68 said:im not sure on that add a thicker oil philosophy... if its a thicker oil, wont the worn rings have a harder time scraping the walls... either way youre gonna burn oil.. although im sure they'res probably a happy-medium that burns the least ammount![]()
