jonheese
Used-To-Know-It-All
I'm in the process of getting my 3.2L engine ready to put into my '90 (it's currently on an engine stand in the garage), and I had a little snafu today...
I was tightening the valve cover bolts on the rear head and one of them broke off at the base of the threads. So I took the valve cover back off, drilled a 5/64" hole in the center of the stuck portion of the bolt and tried my smallest screw extractor: No love, still stuck.
So, I was taking that screw extractor back out to try a 7/64" hole and my next bigger screw extractor, and woops-- dropped the mother-loving extractor in the head, and of course, it goes right down the oil passage in the rear passenger corner of the head, and I can hear it "tink!" down to what sounds like the oil pan.
So, my question is: Is this oil passage a (somewhat) straight shot down to the oil pan? Thus, should the extractor just be sitting in the bottom of the oil pan if I were to take it back off?
The reason I ask, instead of just checking, is that I just buttoned up the bottom end of this engine last week, and I really don't want to drop the pan and have to redo the gasket surface and all that jazz, unless I absolutely have to...
So, assuming the oil drain passage is a straight shot to the pan, does anyone think I won't be okay just leaving it in there until the pan has to come down for something else (hopefully many months/years in my future)? I don't need the screw extractor anymore.
For anyone interested, I was able to get the broken VC bolt out with the 7/64" screw extractor no problem, so the top end is all buttoned up now.
Regards,
Jon Heese
Regards,
Jon Heese
