rocket455
ok while dropping my motor in after 2 years, i get everything set perfect and start bolting everything in. Things are going great! I shimmy under the car and see the drive shaft from the drivers side that comes out of the trans to the passenger side. now on that shaft there is a semi circle bearing that mounts onto the under side of the block to support that shaft so it doesnt sag. my question is have any of you ran into this problem? if so what did you do to fix it? if you havent ran into this, do you have any ideas? thank you
